is it now appropriate to consider, with regards to Conference, perhaps an open tire for Spec Miata in 2012 so that competitiors can continue to use their old R888's, RA-1's as well as upgrade, should they choose, to the new Hoosier, or any other tire they choose.
Just wanted to throw this out for some discussion. Obviously some decision will have to be made regarding 2012, and I personally would like to be involved in the discussions. Thanks.:smile:
Bill
Well Bill, there's 2 ways of going about this:
1: You could have submitted a rules change proposal BEFORE August 1st to change the ICSCC rule for SM to not be based on the Oregon Region SCCA, or it could even state that any DOT tire is allow (like current 2011 GCR states).
2: Since it's too late to submit a rule change for the ICSCC, all you can do is hope that the Oregon Region SCCA changes their SM tire rule to conform to the SCCA national GCR. This wouldn't be all that bad
because... According to the ICSCC rule book your Toyos would still be "legal" for one more year and with the SM6 being $166 that makes them cheaper than buying and shaving Toyos. Hell yeah!
ICSCC SM rule:
ICSCC SM rule said:
C 1319. Spec Miata.
This class shall run under current Oregon Region SCCA rules,
except if the spec tire changes, the previous seasons spec tire will remain
legal for the following race season.
So basically, as far as 2012 is concerned, unless the Oregon SCCA changes their tire rule you get to keep running Toyos.
By the way the SM6 has existed for awhile now and I believe the national SCCA SM's have been running it all this year. That's the Hoosier Jon, Rick and myself run; the SM6 (cuz it's $40 cheaper than the R6 and it's the same damn thing!).
Here's the 2011 SCCA rule regarding SM and tires
2011 GCR said:
9.3.45. TIRES
Tires shall be 124 (“U”) mph rated or better unless otherwise specified
or controlled.
In the Improved Touring, Super Touring, American Sedan, Showroom
Stock, Spec Miata and Touring categories, only DOT approved tires are
permitted. Racing, recapped, or re-grooved tires are not allowed. Tire size
is unrestricted unless otherwise stated. The only modifications allowed to tires are having treads “shaved” or “trued.”
The ICSCC rule book states that SM will adhere to Oregon Region SCCA and this is the rule on the Oregon SCCA GCR:
Oregon SCCA said:
H) Spec Miata Regional (SM): Regional SM entries must use Toyo RA1 or Toyo R888. (Toyo R888 must be
manufactured on or before 12-31-2009.) Size for both tires shall be limited to 205/50-R15. SM entries shall otherwise
follow all GCR rules pertaining to SM preparation.
So you're essentially SOL for 2012 in regards to making an ICSCC rule change because the ICSCC rule book says:
ICSCC 2011 rule book said:
A. No later than August 1, each club’s Contest Board Rep shall call for rule change
proposals from the membership of his/her club, and shall place such proposals
on an agenda for a club meeting to be held within thirty (30) days of the
publication of the club memo or bulletin calling for rule changes.
For next year's reference:
Here is a link to the rules change proposal form:
http://www.icscc.com/forms/rule_change_blank.pdf
And a link to the Rules Change Proposal Form guide:
http://www.icscc.com/references/rule_change_proposal_guidelines.pdf
The ICSCC does not operate like SCCA or NASA. In the ICSCC, if you want something changed it's up to
YOU! :wink:
Does this help? ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
