[Sold] Pro3 race car 1991
Mark Estes
***SOLD***Pro3 Race Car​
Pro3 spec class
The cars are based on BMW’s E30 body style, the Engine is stock, and Suspension is free. Minimum weight
with driver is 2,650 lbs, minimum ride height from rocker panel is 5”. Spec Tire Toyo RA1
See Pro3-racing.com for more information
Car Features (1991 E30 325i)
Custom cage by Racetech Motorsports, Portland
New Saferacer 12 Gal. fuel cell installed by Racetech, Portland
New Seat Belts, FIA certified to (2021)
Sparco Evo2 Race seat
Sparco Right side safety net
Fully Rebuilt Engine by Dynasport (2015)
New Clutch (2016)
New Timing Belt and water pump (2017)
Ground-Control struts and specially valved Bilstein TC Kline rear shocks.
TC motorsports windage crank scraper
TC motorsports Oil pan baffle
Team Dynamics Pro race (1.3) 15 x 7 1 set wheels
Ireland Engineering Rear camber adjusters
Ireland Engineering header
Custom Exhaust by Portland Muffler
Ireland Engineering Mini-lites 15 X 7 wheels (5 wheels) 13.5 lbs each
FabTek strut tower brace
New front calipers, Rotor, pads & SS brake lines all around
Full SPP fire system installed and removable hand held extinguisher
Wired AMB transponder
Sparco steering wheel
Custom gauges from Longacre (tac,oil press, oil temp, water temp, shift light)
Limited Slip Differential (4.10 ratio) rebuilt by Loynings
E.A.T Ultrachip from Mark Dsylva
$15,000
503-734-7355View attachment 1618
