Most of these FC's have a 'spot' on the front belly pan that's considered the place to measure ride height (at the front bulkhead or...). Generally it's as low as you can get it without bottoming the car "too much". (On our Reynard, that was 5/8" ((at Portland)) with 800 Lbs front springs. ADD 1/8" for Pacific) Then, there's some commonly accepted point at the back of the car (can vary from the rear cockpit bulkhead to the bell housing) where you set the rack (On our Reynard, that was 3/4") NOTE: also ran 600 Lbs rear springs.
3 degrees of Caster pretty typical
1.5 degrees negative Camber all round to start (adjust per pyro readings)
1/16" to 1/8" toe OUT each side front
1/16" toe IN each side rear
Used Hoosier tires (cheap from Burget 2nd hand) Starting temps.... 16 Lbs front 17 Lbs rear (shooting for 18 front and 19 rear HOT) Adjust based on pyro readings.
Shocks: Whatever Stimola says
http://www.srpengineering.com/aboutus.php
Of course, all of the above is subject to big changes with the MC engine. And there's nobody up in the Seattle area that has any 'shop' experience that I know of. All of the F1000's are running out of BC and Portland (nearest ones).
BUT, George Dean is in Mountlake Terrace. Although he does 80% or more of the "good" F1000 engines, I'll be he has a good idea of what guys are running for setups. George is also a 'good guy'. Might want to give him a call.
http://georgedeanracing.com/about_george.htm
