colin_koehler
Great SCOTT!
SOLD
Built to SCCA ITA specifications, competes in ITA, ITX, HT and ME3. Currently holds the ITA race track record at Pacific Raceways (1:39.7) set last year in July.
BODY:
Advantage Fleet White single stage paint: https://www.advantagerefinishproduc...nts/704-custom-factory-pack-paint-fleet-white
Bushings
Spherical bushings on front/rear lower control arms except for shock location.
Mugen RTA bushing and poly for remaining locations
I have spherical radius rod bushings but they are not installed
Upper control offset bushings for camber (multiple sets)
Suspension
Koni RACE single adj shocks front/rear. Fronts are new as of 2017
Ground Control Coilovers with Eibach 600lbs front springs and 750 rear
OEM front sway bar
Suspension Techniques 22mm rear sway bar
Engine
D16a6, .020" overbore - balanced/blueprinted by NW Connecting rod in 2016
ARP Head studs, OEM head gasket and manifold gaskets
Manifolds port matched 1"
K&N Filter with aftermarket intake
DC Sports 4-2-1 header with 2.25" exhaust - HushpowerII muffler
NGK iridium plugs and high performance (high temp) Distributor.
180psi compression cold on all 4 cylinders, engine is fresh
Oil cooler
Mishimoto Aluminum radiator with shrouding (you will never overheat)
Transmission/Drivetrain
Refreshed all internals on rebuild in 2015.
MFactory 4.7 Final Drive
MFactory Clutch Plate LSD (100% lock, 1.5 way)
Synchrotech brass synchros.
LSD shouldn't need to be serviced for 2 more seasons
Driveshaft Shop Stage 0 axles with Swepco grease.
Karcepts hubs with Timken bearings new this year. Replaced grease in bearing with Amsoil Dominator racing grease.
Rear hubs are Timken and new as of this year too.
New Calipers as of 2017
Rear discs
Front brake pads are Raybestos ST45 with spare sets (used)
Rear pads are Semi-metallic and ceramic 2 new sets
Brake ducts, ugly but functional!
Interior
Oil temp gauge
Oil Pressure gauge
AFR gauge
OEM Water gauge
OEM tach
Recaro seat with slider
Schroth 6pt FIA HANS belts (the nice ones) that are good through the 2019 season.
Mugen steering wheel with 2" extension and NRG winged quick detach.
Ignition switch replaced with switch panel and push button start. Manual switch for fuel, acc, rad fan
OTHER
Dorman (OEM replacment) baffled fuel tank. Allows me to run less fuel than the OEM tank does.
SPMS Splitter air dam kit with complete spare ready to go on. This is 2 of these which are $500/ea
Wheels/tires
Kosei K1 15x7 with Hoosier H20s
949 Racing 6UL (11ish lbs) 15x7 w/ Hoosier SM7
Advanti DST storm1 15x7 (10.6lbs) w/ BF goodrich R1-S 225/45
I have both 5mm and 10mm spacers and all sets fit with either spacer.
Spares
Complete spare long block and transmission
Complete front knuckles
Rear hubs
Ball joints, tie rods, alternator, distributor, belts, hoses and 1 upper control arm
Rear hatch
Driver side door
Rear bumper
Front bumper skin
Hood
2 sets of axles with Amsoil grease
Springs
Bushings
Other misc stuff like radius rods, cam shafts, lower control arms, tail/head lights etc.
The car will not come with a transponder or the inside window net.
Thank you.
BODY:
Bushings
Suspension
OEM front sway bar
Engine
Oil cooler
Rear discs
Interior
Oil temp gauge
Oil Pressure gauge
AFR gauge
OEM Water gauge
OEM tach
OTHER
Wheels/tires
Spares
Rear hubs
Rear hatch
Driver side door
Rear bumper
Front bumper skin
Hood
Springs
Bushings
Thank you.
