mtnman
![NT-555RII.jpg](http://ssl.delti.com/tyre-pictures/Nitto/NT-555RII.jpg)
High speed stability and durability from Nitto.
These Nitto NT555RII "Extreme R" D.O.T. approved road race and auto cross competition radial tires were developed through a unique fusion between a race circuit oriented stiff sidewall construction and the popular Nitto Drag Radial tread pattern. These features combined with the high traction, specially formulated soft racing tread compound resulted in a competition radial that exhibits impressive control and handling, to provide maximum traction under severe racing conditions. The sidewall construction is optimized for handling extreme lateral acceleration; vehicles may experience rougher riding when used for daily driving. The Nitto NT555RII is designed primarily for competition road racing.
Features include:
* Improved dry traction due to high block rigidity, ultra-high grip compound, and large surface area contact with the road
* Unique tread provides excellent handling capabilities for daily driving
* Two wide steel tread belts and two nylon tread cap plies for superior handling characteristics
* Steel sidewall inserts reinforce the sidewall for extreme lateral acceleration
* Jointless tread cap plies and jointless wound bead wires improve tire uniformity and provide a smooth, comfortable ride
* Unidirectional tread pattern allows for high speed and excellent braking response
* Unique construction and tread pattern improve rigidity, uniform contact, and wear resistance
* Spiral wound, jointless bead wire construction assures strength for stable performance at high speeds
* Rim guard designed to protect against wheel damage
Call 206-367-1471
