mtnman
1979 Capri open track car less than 6 hrs TT (estimate 80-100 miles)
Titled /not street legal
7 point cage /2x3 integral subframe connectors/ adjustable Stainless Steel panhard bar,3 L/S door bars ,1 R/S door bar.Rear suspension heim jointed /ride height adjustable lower control arms/Lexan side & rear window.OEM front air dam
PAINT Deltron$2000.00
REAR END Speedway engineering full floating assembly $1500.00
9” Ford 31 spline/3:70 Ford Gears/Detroit Locker $1200.00
R/ROTORS 13” Dia..810 thick rotors $130.00
R/CALIPERSWilwood Dynalite W/Porterfield Carbon Kevlar pads $300.00
Braided flexible brake lines $60.00
R/SHOCKS Koni adjustable $300.00
ENGINE: 351Windsor 385 HP Ford crate motor $6500.00
PAN Canton road race 8qt pan $375.00
BELLHOUSING Lakewood scattershield $400.00
CLUTCH Centerforce Dual Friction (2 hrs) $385.00
CARB Holley 750 DP/ HP series $650.00
FUEL PUMP Carter $100.00
WATER PUMP Edelbrock $165.00
STARTER Ford Mini $200.00
TRANSMISSION Ford toploader 4spdw/Hurst comp. plus linkage $1500.00
HEADERS custom fabrication/ 1 ¾ dia./ceramic coated $850.00
EXHAUST3” exhaust w/flow master mufflers $400.00
RADIATOR Ron Davis radiator w/dual Spal electric fans & shroud $600.00
OIL COOLER2”x4”x18” w/-10 hose and AN fittings $250.00
IGNITION MSD 6AL box and coil $265.00
GAUGES Autometer 2 5/16 gages W/T,O/T,O/P,F/P,AMP,Hr/M $500.00
DRIVELINE Ford/ Alum $275.00
GAS TANK Fuel cell 16. gal $475.00
SEAT/BELTS Alum/ 5 point belts $200.00
Quick release steering wheel $100.00
AN fittings & steel braided hose $250.00
AN hydraulic fittings/adjustable brake bias valve $150.00
FRONT SUSPENSION Bilstein Cobra R struts w/ coil over conversion $900.00
Bump steer kit Ford $235.00
SPINDLES 94 Cobra $250.00
F/ROTORS/CALIPERS 94 Cobra 13” Rotors/ calipers Carbon Kevlar pads $375.00
STEERING RACK SVO quick ratio power rack $300.00
Braid flexible brake lines $65.00
MASTER CYLINDERSVO1.25 DIA $100.00
TIRES Kuhmo Victor racer V700 245-45x17 275-40x17 $700.00
WHEELS Ford Cobra R 17x817x9 $500.00
U-JOINTS Spicer 1330/1350 $100.00
BATTERYOPTIMA $160.00
ROLL CAGE 7 point …$200.00
TOTAL PARTS(No labor)$23865.00
Will sell for 80 cents on the dollar
Earle Baird 206-715-9831
WEIGHT +/- 2846 LBS w/o driver
![5812605771_2e7a266433_m.jpg](http://farm3.static.flickr.com/2260/5812605771_2e7a266433_m.jpg)
![5812603135_4e22821dd2_m.jpg](http://farm6.static.flickr.com/5160/5812603135_4e22821dd2_m.jpg)
![5812606807_e671e0e362_m.jpg](http://farm3.static.flickr.com/2282/5812606807_e671e0e362_m.jpg)
![5813172316_5cfdd3b188_m.jpg](http://farm6.static.flickr.com/5031/5813172316_5cfdd3b188_m.jpg)
![5813169920_a3ea751212_m.jpg](http://farm6.static.flickr.com/5143/5813169920_a3ea751212_m.jpg)
![5812602657_fee4882fac_m.jpg](http://farm6.static.flickr.com/5035/5812602657_fee4882fac_m.jpg)
