Mike,
Here are a few images that are a little bigger, hope they help with the sale.
Okay, I give, what's a studded motor?
any pics of the trailer?
Has "studs" installed for head retention instead of the OEM head bolts. If running higher then stock compression ratio M50/S50 motors need these. Also added benefit is studs are reusable where the OEM bolts stretch and must be replaced once loosened.
Mike good luck with your sale. Man that is a pretty car!
Might want to post it up on Bimmerforums if you have not already. They have a very active race car/race parts subforum there.
I am sure two race cars in the same house hold is a problem. I can hear them now..."I was first..." "Yea whatevera I am newer...."
PS Your a lucky man to even get to two race cars. My wife barely tolerates the one I have.![]()
Thanks Scott. I tried to post on Bimmerforums but i could not b/c I have have insufficient status. Not a member long enough or not enough posts.
Yes, the wife is very understanding and I am lucky.
Mike, I can post it up for you if you would like me too? Remind me tonight and I will do that if you want. I can't access that forum from work.
How much does the trailer weigh and what did you use to tow it?
Don't want to trade straight up for a slightly un-running Subaru do you?
Good luck with the sale. I've been passing the ad around to some of my buddies that I want to get involved in racing.. so far no takers.
